Steamer Repipe
EzzyT
Member Posts: 1,377
We repiped this Utica steamer with a drop header and our standard water seal for the pressuretrol and gauges.Upgraded the main venting and installed a analog meter with resettable counter.
Just need to go back to skim and wand the boiler some more and install a Demineralize inline filter.
Also replaced the water heater with a Caleffi Tankmixer and ThermalExpansion Tank with support bracket.
Thanks to @clammy for helping us out on this one too.
2
Nice job.Bob Boan
Did the mungo pay for the repipe? 🤣 Awesome as always.0
Looks good Ezz, even a Utica, got to be better than before.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
As always Ezzy it’s always a pleasure working with someone who knows and always does the right thing instead of doin the wrong and calling it good enough . When u have been doing this as long as I have it’s awesome to see some one younger Carrying on a tradition of quality and craftsmanship that is not seen in most homes mechanical rooms that I see it’s really extremely nice to known there’s still guys out there who personally do the work themselves instead of sending workers to do the dirty work . As always it s always a great day of spinning and bs talk when work along Ezzy a true craftsman’s and a nice guy on all levels . Thanks again ezzy Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
I'm confused about the boiler with the near boiler copper piping?0
@question the copper piping on the boiler is the old piping. We repiped it with steel and cast fittings.1
Why doesn't the boiler have pigtails on the gauges and pressuretrol?
He accomplished the same thing with that pipe that drops down and forms a trap but you can flush it out by just removing those plugs, you don't have to take it apart to clean it.question said:Why doesn't the boiler have pigtails on the gauges and pressuretrol?
"We repiped this Utica steamer with a drop header and our standard water seal for the pressuretrol and gauges."1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
