2 Steamers In One House
EzzyT
EzzyT Member Posts: 1,377
We replaced 2 oversized leaking steamers with 2 Crown BSI-69,000 btu steamers. Piped with our standard 3” drop headers, water seals, demineralized filters and analog meters with resettable counters.
Would like to thank @clammy for helping us out on this one.
Just need to go back to replace the radiator vents, skim and wand the boiler some more.
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
STEVEusaPAPrecaud
  • STEVEusaPA
    Looks awesome as usual Was the flue pipe a PIA?
  • EzzyT
    Thanks Steve, not so much.
    201-887-8856
  • jumper
    jumper Member Posts: 2,494
    Is the plan to isolate one except when you require both?
    In the seventies some building owners replaced big boilers with multiple smaller ones. I think the scheme worked better for steam than HHW.
  • EzzyT
    No this is a two family house with each apartment having there own steam systems. The tenants pay for there own heat and hot water.
    201-887-8856
  • luketheplumber
    luketheplumber Member Posts: 160
    I guess this is the only right was to zone steam without any problems.
    Located in durham NC.
  • jumper
    trv s work well for two pipe steam. Blanketing radiators also works.
    luketheplumber
  • clammy
    clammy Member Posts: 3,241
    As always Ezzy it’s always a pleasure working together nothing nicer then working w those who always aim to do the best and never come up short on the delivery and are always geared up to get the job done without short cuts . That by itself is far and few between in these days and it makes doing the job a pleasure no matter how tight a space and knowing that there will never be anything missing and always extra just in case , again always a pleasure spinning w you guys and there’s never a doubt that it will be done and be done right . True craftsman’s of the trade . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    STEVEusaPAluketheplumberethicalpaul
  • gerry gill
    gerry gill Member Posts: 3,083
    You rock Ezzy..simply outstanding.
    gwgillplumbingandheating.com
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Nice looking job.  How are you liking the Crowns?
  • EzzyT
    Thanks @clammy it’s always a pleasure and fun to work along side you.
    Thanks @gerry gill you and many others here on this site have taught me so much over the years and I’m truly great full for that.
    Thanks @Dan Foley there a decent boiler besides having to remove almost all the jacket in order to remove the factory plugs.
    None of the wholesaler in NJ stock knock down residential boilers there always a special order.
    201-887-8856
