2 Steamers In One House
EzzyT
Member Posts: 1,380
We replaced 2 oversized leaking steamers with 2 Crown BSI-69,000 btu steamers. Piped with our standard 3” drop headers, water seals, demineralized filters and analog meters with resettable counters.
Would like to thank @clammy for helping us out on this one.
Just need to go back to replace the radiator vents, skim and wand the boiler some more.
2
Looks awesome as usual Was the flue pipe a PIA?
Is the plan to isolate one except when you require both?
In the seventies some building owners replaced big boilers with multiple smaller ones. I think the scheme worked better for steam than HHW.0 -
No this is a two family house with each apartment having there own steam systems. The tenants pay for there own heat and hot water.0
I guess this is the only right was to zone steam without any problems.
Located in durham NC.
trv s work well for two pipe steam. Blanketing radiators also works.luketheplumber said:I guess this is the only right was to zone steam without any problems.
As always Ezzy it’s always a pleasure working together nothing nicer then working w those who always aim to do the best and never come up short on the delivery and are always geared up to get the job done without short cuts . That by itself is far and few between in these days and it makes doing the job a pleasure no matter how tight a space and knowing that there will never be anything missing and always extra just in case , again always a pleasure spinning w you guys and there’s never a doubt that it will be done and be done right . True craftsman’s of the trade . Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating3 -
You rock Ezzy..simply outstanding.gwgillplumbingandheating.com
Nice looking job. How are you liking the Crowns?0
Thanks @clammy it’s always a pleasure and fun to work along side you.Thanks @gerry gill you and many others here on this site have taught me so much over the years and I’m truly great full for that.Thanks @Dan Foley there a decent boiler besides having to remove almost all the jacket in order to remove the factory plugs.None of the wholesaler in NJ stock knock down residential boilers there always a special order.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
