Off Topic: Hoisting Hooks On Amsterdam buildings
D107
Member Posts: 1,852
I've been told NYC has these too, but I've never noticed one. Given the relatively thin brick walls, I wonder what the max load would have been. Were these for people moving their belongings in? Can't see them supporting a piano. In Europe I have seen long electric or hydraulic ladders being used for deliveries, etc.
It seems they would need to hang a big pulley on that hook with one rope tied around the furniture piece on the ground and with a few men on the ground pulling the other end of the thick rope. But how to attach the pulley to the hook? From the closest window?0
Exactly. Those hooks go back a very long time.Retired and loving it.0
Retired and loving it.2
What could possibly go wrong?Retired and loving it.0
If only they’d asked Laurel and Hardy for help...0
That concept came to the "New World" of the Midwest where prairie grass (Hay) was cut, dried and stored for winter livestock feed.
The large barns you might see had a huge hay loft to store the hay, tons of it.
Most had a steel trolley beam from the rear of the loft to beyond the front. If you see an old barn like this it has the front end gable pitched/beaked out for the beam.
There was a grapple claw hook that would drop down to the ground or wagon and close the claw around the hay, when it was pulled back up.
Then when it come to the beam it would travel to the back of the barn along the beam track. At some point the claw would open and the hay drop to the loft floor. I believe there was a hanging rope to pull to dump the claw where you wanted it.
There is some mechanism that would change the vertical lifting to travel along the track.
(I have never examined one but it must be ingeniously simple as much of these old systems are.)
A long rope and pulleys attached to a good team of horses did the work. Horses would learn their job and know when to back up for the next lift.
No one uses these any more, I have only seen a video of the process. It is pretty slick how quick it works.
In those days this was the only easy job of moving hay, it was almost like firewood, handled many times, but with a pitchfork.
I would guess that somewhere out here there is a piano stored in a hay loft as the haying methods have changed and lofts have turned into attics for that type of thing.0 -
Not just the midwest. A surprising number of barns in New England had such hoisting beams. In fact, I'd go so far as to say that unless the barn was built so you could bring the wagons in on the loft level, and the critters were on the level below, it was pretty normal.
@JUGHNE describes the whole mechanism pretty accurately -- except to note that the track arrangement was a new-fangled invention coming in in the mid to late 1800s...Br. Jamie, osb
We are pretty flat land here. Never seen a 2nd floor drive in for a barn, other than movies.
Did see a TV documentary on the compromise the Amish would make for using internal combustion engines.
They would put up hay with old methods but might use a gas power conveyor to put small square hay bales up to the loft.
IIRC, the theory was to not go completely with power machinery so that more manpower was needed to get the harvest in.
There was only so much land and so many offspring.
We have had some Amish buy farm land in the east part of NE.
The came from Iowa as there was less farm ground available.
They produce everything from cleaned frozen chickens (inspected BTY) to new custom built windows.0 -
These days I think they do it more this way--seen this in Amsterdam and Paris.
use a block and tackle on the hook, not just a single pulley and get the mechanical advantage0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
