Two system replacement
Dave0176
Member Posts: 1,178
Big house built in 2005 had two ICP AC systems installed. House is now for sale and vacant, not selling, so the realtor decided maybe it would be a good idea to replace the AC systems since neither are working. House has a 4 ton and a 3 ton. Unfortunately the condensers are beat because the old owner had a dog and his favorite urinating spot was on the 3 ton condenser lol. That rotted the hell outta the aluminum fins leaving only the copper. The original install was shabby as is in most development housing projects. Trunk with flex running everywhere. But it’s not my job to replace the whole system just the equipment. So we’re on our way.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
1
What's the oil tank used for?All Steamed Up, Inc.
Consulting0 -
A portable brake and electric seamer would be good investments. Hope you masked all those joints.0
I hope the blower motor never fails on the rear unit......0
Oil tank. Must have hot water baseboard doubt they have two duct systems. Looks good!!!
It's hard to get a decent duct job most original installers go flex on everything, reduces the hell out of the capacity. Some flex is ok but most jobs have way too much0 -
Getting there.
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Domestic hot water and baseboard heat. Has an oil fired Peerless with a large indirect tank. I serviced that too vacuumed out about 4” of soot from the combustion chamber. LolSteamhead said:What's the oil tank used for?
All is good and yes those tools would be nice, make my job quicker too.HVACNUT said:A portable brake and electric seamer would be good investments. Hope you masked all those joints.
There’s plenty of space between the units. A good 36”-40”realliveplumber said:I hope the blower motor never fails on the rear unit......
I cannot force people to spend money, I can only suggest how to spend it wisely.......1
