NY Times: After Coronavirus, Office Workers Might Face Unexpected Health Threats
D107
D107 Member Posts: 1,911
edited June 2020 in THE MAIN WALL
"Stagnant plumbing systems in emptied commercial buildings could put returning employees at risk of Legionnaires’ and other illnesses." I wasn't aware that the virus can be spread by a flushing toilet--shower spray, yes. I'd like to hear the Wallies' take on this.
https://www.nytimes.com/2020/05/20/health/coronavirus-legionnaires-offices.html?algo=identity&fellback=false&imp_id=128845880&action=click&module=Science Technology&pgtype=Homepage
    EdTheHeaterMan Member Posts: 10,671
    Business opportunity!
  • Canucker
    Canucker Member Posts: 723
    I would imagine that you can spread the bacteria if you flush the toilet with the lid up as it will aerosolize the water droplets. I don't know how likely it would happen that someone would become ill from it but it is possible
    You can have it good, fast or cheap. Pick two
    mattmia2D107
  • ratio
    ratio Member Posts: 4,040
    Oh, no—mandatory diapers‽‽‽‽
    pecmsg Member Posts: 6,243
    Closed buildings DO Have issues. HVAC has been shut down, no outside air, no dehumidification. Mold has been growing. Like anything else a complete clean up is needed, Systems run for several days. Air monitoring the entire time. This is going to be one of the costs of this Shut Down!
    D107
    hot_rod Member Posts: 25,251
    D107Canucker
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Also this from Germany:
    https://p.dw.com/p/3dFxe
