Uponor bend support question
ChrisJ
Member Posts: 17,060
So I've got a silly question.
I originally wasn't going to use any of these and instead I ended up using them constantly..
This is about the bend supports that snap onto the tubing to hold it in a tight radius.
Can I have two of them close together to form a tight 180 degree loop? Or to turn 90 up and then 90 left, or right etc? Like literally two Back to back?
Also how close to a fitting can they be? I assume it doesn't matter as long as I can expand the exposed end?
https://www.supplyhouse.com/Wirsbo-Uponor-A5250500-1-2-Plastic-Bend-Support-2128000-p
I can't see any of this being an issue but you never know...
How exactly can you use them somewhere that doesn't require bending..................ratio said:I'd be comfortable with them anywhere that didn't require any bending/adjusting/mutilation to get 'em to fit.
You can have the bend supports back to back and best to leave a few inches of space between bend support and fittings.2
@Danny Scully's got it. I think you might even be able to get the ends to overlap slightly if you put the brackets on opposite sides of the PEX1
