Uponor bend support question
ChrisJ
ChrisJ Member Posts: 17,294
So I've got a silly question.
I originally wasn't going to use any of these and instead I ended up using them constantly..
This is about the bend supports that snap onto the tubing to hold it in a tight radius.
Can I have two of them close together to form a tight 180 degree loop? Or to turn 90 up and then 90 left, or right etc? Like literally two Back to back?
Also how close to a fitting can they be? I assume it doesn't matter as long as I can expand the exposed end?
https://www.supplyhouse.com/Wirsbo-Uponor-A5250500-1-2-Plastic-Bend-Support-2128000-p
I can't see any of this being an issue but you never know...
  • ratio
    ratio Member Posts: 4,219
    I'd be comfortable with them anywhere that didn't require any bending/adjusting/mutilation to get 'em to fit.
    ChrisJCanuckerZman
  • ChrisJ
    How exactly can you use them somewhere that doesn't require bending.................. :p
  • Danny Scully
    Danny Scully Member Posts: 1,465
    @ratio means bending the actual support @ChrisJ. I think you’re good with what you suggested 👍
    ChrisJ
  • EzzyT
    EzzyT Member Posts: 1,379
    You can have the bend supports back to back and best to leave a few inches of space between bend support and fittings.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Rich_49ChrisJ
  • ratio
    @Danny Scully's got it. I think you might even be able to get the ends to overlap slightly if you put the brackets on opposite sides of the PEX
    ChrisJ
