Ping, Ping, Ping
rhw1
Member Posts: 32
This is probably the millionith time this has been discussed but trying to figure out if my slow mind has missed something. Boiler has been re-piped and pipes are insulated. Upon starting things are mostly quiet with the exception of one radiator. This is a one pipe system and radiator seems properly pitched. It just pings loudly for a while. Vent holds a slight amount of water but does not drip or hiss. What should I check or do? Thanks.
Is it a ping? Or a bang? If it's a ping, put something slippery under the feet -- like pieces of old milk jug -- and check where the pipes come through walls and floors and add bits there, too, if they seem like they can touch.Br. Jamie, osb
The wood floor around the riser could be touching . Slide a small sheet of that milk jug between the pipe and the wood .
pitch of the run out branch that feeds the radiator. <- This part especially!!EBEBRATT-Ed said:Check radiator pitch pitch of the main and pitch of the run out branch that feeds the radiator.
Is it the largest radiator? Just curious.
1950 Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.
Not the largest. 30 1/2 L by 19 1/2 H.0
Oh well. That shoots my theory
If really is expansion noise, it's almost impossible to predict which radiators -- or pipes -- might do it. Best one can do is to try to locate it. And then one can sometimes do something about it -- and sometimes just stare at it with dismay. Sometimes it will be a big radiator. Sometimes a little tiny one.
Frustrating...Br. Jamie, osb
whats the best (easiest) way to lift the radiator in order to slip a shim under it?0
@rhw1
a crowbar and some wood blocking to get the crowbar in the right spot. No fingers under the radiator!!!1 -
My crowbar isn't very long so I always used a 3 or 4 ft 2x4 and some blocking to lift a radiator. Do it gently so nothing unfortunate happens.
3PSI gauge0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
