Time on your hands?
https://www.youtube.com/watch?v=ACO-HXvrRz8&list=PLf0IJmoCsLHm1z7RrsJ6HLV9ISu64DLhv&index=2&t=0s
https://www.youtube.com/watch?v=rUg_ukBwsyo&list=PLf0IJmoCsLHm1z7RrsJ6HLV9ISu64DLhv&index=2If you can get your hands on one it should provide endless opportunity to display your steam skills.
Bob
3PSI gauge
How do you sharpen a Stillson wrench?Just another DIYer | King of Prussia, PA
I have a new TIG welder on the way. I can do stick and MIG already, but with the addition of my aluminum boat 2 years ago, I figured this was the time to step up and learn something new.0
@Hap_Hazzard , you cant, but you can sharpen your mind:-)0
I like it. I have a TIG setup for my Multimatic 200 still in the box.KC_Jones said:I have a new TIG welder on the way. I can do stick and MIG already, but with the addition of my aluminum boat 2 years ago, I figured this was the time to step up and learn something new.
Albert Einstein0 -
Mine is an "off brand" from a company called Prime Weld. I don't have the money for a Miller/Lincoln/ESAB set up so I went with this.Zman said:
I actually follow a fabricator on youtube called 6061.com, he is incredible with a TIG torch. He has one of the Prime Weld TIG welders that I ordered and said it works fantastic. I liked the under 1k price tag for an AC/DC TIG setup. DC is fairly easy to find a good deal on, but for Aluminum I need the AC, so the price goes up.1 -
Hi @Hap_Hazzard , This may be strange, but I actually do sharpen my pipe wrenches.
The teeth get rounded over the years, so I take a Dremel with a biggish grindstone on it. and run it by each tooth on the wrench. The stone needs to have a sharp right angle in it. The tools grab SO much better with sharp teeth that my knuckles don't get banged up any more! And I've been doing this since BEFORE covid 19
Yours, Larry1 -
@Larry Weingarten
I used to think Dremels were toys and they are but that toy has bailed me out a few times when nothing else will work.
I have used it to sharpen those metal step bits that are pretty pricey2 -
@EBEBRATT-Ed A dremel is not my most used tool but it's worth it's weight in gold. Same thing for an oscillating cut off tool, it only does a few things really well but often there is no other option.
3PSI gauge0 -
For plunge cuts there's nothing like them.BobC said:A dremel is not my most used tool but it's worth it's weight in gold. Same thing for an oscillating cut off tool, it only does a few things really well but often there is no other option.
You might get better results by removing the jaws and taking them to your bench grinder. A green wheel would work best.Larry Weingarten said:This may be strange, but I actually do sharpen my pipe wrenches.
Hi @Hap_Hazzard , I agree with you for the Stillson type wrench where the jaw is easily removable, but with other styles, that would be interesting. I just like old automatic pipe wrenches!!
Yours, Larry
I remember those from the wrenches thread. Pretty neat. But are those jaws hardened? If they are, I'd use a diamond sharpeneing stone or a diamond emery board.Just another DIYer | King of Prussia, PA
Hi @Hap_Hazzard , You must be a wrench nerd also
The two pictured are hard to file, but I suppose it could be done. I do have some other wrenches where a sharp, fine file just slides and can't bite. A sharp triangular file might be good also for sharpening tools that will accept a file. I'm thinking your approach leaves nicer looking teeth than a Dremel. More than one way to pet the cat!
Yours, Larry0 -
Yeah, @Larry Weingarten, files don't bite into hardened steel. That's one test that's used after heat-treating.
If you can find one of those little diamond emery boards, or nail files, that's the ticket. They can get into tight spaces and cut hardened steel. Just don't press too hard, because they bend, and you won't get a flat edge. And don't use any cutting oil. Diamond grit likes water, but you can use them dry and then wash them later.
Here's a picture:
They sell them in drug stores, and they usually have different grits on each side, which is handy.Just another DIYer | King of Prussia, PA
- 116 Geothermal
- 15.8K Strictly Steam
- 52 Industry Classes
