Constant Banging In Parallel Flow System
New England SteamWorks
Member Posts: 1,529
Condensate isn’t returning either. I just can’t seem to put my finger on the cause...
newenglandsteamworks.com
I'm afraid to bite since you know more about steam than i do, do you speak in jest?0
You have to be kidding, Ryan. You've forgotten more about steam than I ever knew...Br. Jamie, osb
Let me guess, nobody else could figure it out. Wow, just wow.0
Now that I look at it again... you're only a few days early!Br. Jamie, osb
Once again- you can't fix stupid!All Steamed Up, Inc.
Consulting0 -
SMHJust another DIYer | King of Prussia, PA
Poor guy. His plumber told him that his steam pipes looked old (!) and should be replaced. Which he did, mains, returns, and run-outs. Cost more than a boiler install and everything pitched wrong.
Worst part for us is he used press fitting. So we can’t just unscrew and correct. No. We have to cut and thread in place.New England SteamWorks
newenglandsteamworks.com0 -
Then there’s the inexplicable: Let’s do one runout in copper and pipe it in such a way that the bulkhead door can only open halfway:New England SteamWorks
Why would he do that? Because he could!New England SteamWorks
Dang. All my pipes look pretty old. I didn't know that meant they had to be replaced. Should there be a "best used by" date on them somewhere?Just another DIYer | King of Prussia, PA
“Best Used Until They Leak”New England SteamWorks
ButNew England SteamWorks
But, we are making progress...New England SteamWorks
newenglandsteamworks.com1 -
That's really sad that contractors need to steal like that to have a business. Yes that's harsh, but it's reality.3
Not just stealing. That system was vandalized.Just another DIYer | King of Prussia, PA
Header is too small as well isn't it?New England SteamWorks said:But, we are making progress...
Yes, it’s a bit small. But the poor guy has already spent a fortune, so we are trying just to get it to work, but with minimum required specs.New England SteamWorks
HA, HA!0
The first thing that I noticed was the steam outlet pipe has a reducing coupling on it. That's a No No'
Can not see the near boiler piping to make a judgement call on it.
Can not see why the return is higher than the steam main.
If this O.K. Where does the end of the steam drip tie into? Hopefully a wet return.
Real costly problem to fix
Jake
See the simplified boiler piping dwng.Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 50 Industry Classes
