Constant Banging In Parallel Flow System
Condensate isn’t returning either. I just can’t seem to put my finger on the cause...
New England SteamWorks
newenglandsteamworks.com
  • GW
    GW Member Posts: 5,137
    I'm afraid to bite since you know more about steam than i do, do you speak in jest?
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    Jamie Hall Member Posts: 26,838
    You have to be kidding, Ryan. You've forgotten more about steam than I ever knew...
  • KC_Jones
    KC_Jones Member Posts: 5,907
    Let me guess, nobody else could figure it out. Wow, just wow.
    2014 Weil Mclain EG-40
    Now that I look at it again... you're only a few days early!
  • JUGHNE
    JUGHNE Member Posts: 11,513
    I think you posted the picture upside down just to trick people.
    Steamhead Member Posts: 18,205
    Once again- you can't fix stupid!
    Consulting
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    SMH
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,529
    Poor guy. His plumber told him that his steam pipes looked old (!) and should be replaced. Which he did, mains, returns, and run-outs. Cost more than a boiler install and everything pitched wrong.
    Worst part for us is he used press fitting. So we can’t just unscrew and correct. No. We have to cut and thread in place.
    Then there’s the inexplicable: Let’s do one runout in copper and pipe it in such a way that the bulkhead door can only open halfway:
    Why would he do that? Because he could!
  • Hap_Hazzard
    Dang. All my pipes look pretty old. I didn't know that meant they had to be replaced. Should there be a "best used by" date on them somewhere?
    “Best Used Until They Leak”
    edited March 2020
    But
    But, we are making progress...
    STEVEusaPA
  • KC_Jones
    That's really sad that contractors need to steal like that to have a business. Yes that's harsh, but it's reality.
    New England SteamWorksHap_Hazzardethicalpaul
  • Hap_Hazzard
    Not just stealing. That system was vandalized.
  • KC_Jones
    Header is too small as well isn't it?
    Yes, it’s a bit small. But the poor guy has already spent a fortune, so we are trying just to get it to work, but with minimum required specs.
  • Fred
    Fred Member Posts: 8,542
    HA, HA!
  • dopey27177
    dopey27177 Member Posts: 916
    The first thing that I noticed was the steam outlet pipe has a reducing coupling on it. That's a No No'
    Can not see the near boiler piping to make a judgement call on it.
    Can not see why the return is higher than the steam main.
    If this O.K. Where does the end of the steam drip tie into? Hopefully a wet return.
    Real costly problem to fix
    Jake
    See the simplified boiler piping dwng.
