Should I shut down my Buderus G215 boiler before a planned water line shut down?
ECMO1
Member Posts: 1
Should I shut down my Buderus G215 boiler before a planned water line shut down? City guidance suggests taking system off line if I have a hot water heating system combined with a hot water heater. Thanks for any help.
No need to shut it down if it isn't losing water somewhere where it shouldn't be. Generally heating systems in good shape don't need any water feed -- or at most, very little. I'd just close the manual feed valve to it and let it go. Is the hot water heater part of the boiler, or is it separate? Is it just a coil in the boiler? In either case, you'd be fine (and save yourself some crummy looking hot water later! By closing the valve going to the hot water heater as well. If it's a separate hot water heater I'd turn it off for the duration.Br. Jamie, osb
