What the heck is wrong with Honeywell?
13»
  • D107
    D107 Member Posts: 1,945
    Ho here. On advice from this site, got a Honeywell T6 Pro (TH6210U2001) currently at supply house for not much more than you paid for your unit, all sorts of bells and whistles. have had it for entire heating season: excellent.
    SuperTech
    HVACNUT Member Posts: 7,451
    One of the BEST of the Bells and Whistles is that you can program it to have no Bells and Whistles.
    Heat only
    No program schedule.
    No fan button.
    No sweat.
    D107SuperTechBillyO
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    I ended up getting a used Honeywell CT87A thermostat. I found one on ebay for $18. It's a round, analog thermostat with a mercury switch and an anticipator. I've had it installed for a few weeks now, and I'm very happy with it. The weather hasn't been super cold since I installed it, but it seems to keep the temperature very steady. Unless you're really paying attention, you don't even notice the heat's on.
    rick in Alaska
  • Steve Minnich
    Steve Minnich Member Posts: 2,876
    edited May 2020
    @ChrisJ - Tell us about that AC you installed. Did it meet your minimum expectations? You seem to want it both ways here? 😎
    Miss me on FB? 😂
    Steve Minnich
  • ChrisJ
    ChrisJ Member Posts: 17,389
    > Miss me on FB? 😂
    Performance wise yes, build quality wise no and the problems stunk.
    Im confused though, I want what both ways?
  • Steve Minnich
    @Hap_Hazzard has the expectation that his thermostat should be reasonably accurate. Being 5 degrees off falls way short of that, so he has every right to voice his displeasure. 5 degrees off is simply unacceptable when you're trying to control an indoor environment.
    You also had expectations of your product that fell short.
    You feel it's ok to gripe about your product and rightfully so, but it's not ok for him.
    Steve Minnich
  • ChrisJ
    Maybe you're right.
    Why did you leave FB again?
  • Steve Minnich
    @ChrisJ Same reason as always, politics. Now, let’s get back to heating. .
    Steve Minnich
    I think its supposed to be a nice day tomorrow.
