Radiant Manifolds and Fire Walls
winesalot
Member Posts: 32
I have a radiant system I am installing that was designed by Harvey Ramer. (I would highly recommend hiring him to design your system, he was wonderful to work with.) What I failed to realize in the planning stage is that 4 of the 5 radiant manifolds are in 2-hour fire walls. When I placed the tubing I brought it up right in the middle of the 2 sheets of 5/8" drywall that makes up the 2-hour fire system. I am not sure what the best way would be to proceed with the manifold installation. Thoughts?
One idea I am considering is to push the tubing and manifolds to the wall interior and install a fire rated door like this: https://www.supplyhouse.com/Acudor-FB-5060-18x18-18-x-18-Fire-Rated-Access-Door-6796000-p
1
To maintain the fire rating, you must have the required total thickness of fire rated sheet rock -- or a fire door. Lots of ways to do it. One thing to watch, though, is that any openings in the sheet rock for pipes to pass through must themselves have fire rated closures -- fire stopping insulation or something of the sort -- and the pipes must be fire rated.Br. Jamie, osb
Thanks for the input. This has been helpful.0
