Which is more economical
2»
    Jamie Hall Member Posts: 26,831
    I think @Henry does have data which suggest that his conversions save money. And I wouldn't argue with that. However... I also seem to recall that he works in or around Montreal, and if what I have seen of heating systems in Montreal, which is a very small sample (half a dozen or so) in most cases you could save money by burning cash in a fireplace. So without knowing the condition of the replaced system, we really don't know very much.
    Canuckerratio
    hot_rod Member Posts: 26,575
    And one could certainly give kudos to Henry for making those system better, Canadian or not💎
    Brewbeer
    Steamhead Member Posts: 18,193
    Which is the point I and several others made in that previous thread. Henry's claims so far have no merit because we do not know what was there before, what condition it was in etc. The same is true for every "case study" I've seen. IIRC, the only exception was one in a school, where the steam boilers were being controlled manually. That's right, manually- indicating a complete control failure. Yet the savings were presented as an indictment of steam, when they were actually a sad commentary on the school's maintenance department. I suspect those new mod-cons have lost a considerable portion of their efficiency by now.
    Contrast that with others, including mine. Short version is: This is what we found, this is what we did, this was the result. If we don't have all this info, the numbers mean nothing.
    Henry has also failed so far to state the heat loss of his house. He does say it's 2,000 square feet, but how much heat is actually needed to keep it warm? Again, for the numbers to mean something, we need this info. Anything less does this community a disservice.
    As for obsession- well, some people are obviously obsessed about their mod-cons, aren't they?
    Consulting
    Mod con envy Steamhead 😏
    Solid_Fuel_Man
    Do your customers give their guests boiler-room tours, as some of ours do?
    Consulting
    We all bow to you as the resident steam guru. I’d expect no less than both you and the customer celebrating your work and knowledge 🤓
    edited March 2020
    hot_rod said:
    We all bow to you as the resident steam guru......
    How about @DanHolohan , @Dave0176 , @JohnNY , @Gordo , @The Steam Whisperer , @Jamie Hall , @EzzyT , @ttekushan , @JStar , @gerry gill , @Mad Dog and whomever else I forgot to mention? I know I've learned a lot from them.
    Consulting
    We have all learned a lot from each other, you can share that guru status with those mentioned and many others.
    But in my mind there is only one Steamhead🧰🔧
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    My fuel & electric use is less than half of all similar (or smaller) homes in my area.
    Boiler room tours are mandatory to the point that my wife has to come get us because the other wives wonder where we are, my wife always knows where we are.
    ...... Boiler room tours are mandatory to the point that my wife has to come get us because the other wives wonder where we are, my wife always knows where we are.
    Well, at least she doesn't have to track you using GPS >:)
    Consulting
    Solid_Fuel_Man
  • KC_Jones
    KC_Jones Member Posts: 5,907
    My wife refers to my boiler as "my girlfriend".
    2014 Weil Mclain EG-40
    ratioErin Holohan Haskell
  • Solid_Fuel_Man
    She actually calls mine "the mistress"! But she also calls my 1959 Ford "the lady" so there's that.
  • PerryHolzman
    PerryHolzman Member Posts: 236
    Steamhead: I give tours of my boiler all the time... To show people what can be done - if done right. I do warn them about the cost and the fact that no one in the area knows how to service my Viessmann Vitodens 200... along with other interesting suggestions.
    Come visit if you get to Eastern Wisconsin (that invitation is open to anyone).
    Perry
    Solid_Fuel_Man
