P
JPL941
JPL941 Member Posts: 51
edited August 2023 in Plumbing
Helo
  • BillyO
    BillyO Member Posts: 277
    Definitely an improper installation. I would absolutely use it in my own home
    kcoppIronmandelta TZman
  • Ironman
    Ironman Member Posts: 7,722
    I can make a sweat joint as nice as any mechanic around, but for the last 10 years, ProPress is all we've used unless a sweat fitting was the only type available.
    Out of the thousands of joints we've done, I've had less than five leak and every one them was because the crimp was wrong.
    Bob Boan
    delta T
  • Intplm.
    Intplm. Member Posts: 2,651
    Propress is tried and true. Have been using propress for years with little to no problems.
    The few horror stories you may have read are probably incorrect installation problems.
    IronmanBillyO
    Alan (California Radiant) Forbes Member Posts: 4,469
    edited March 2020
    Same here, ProPress rules. But why do you want to reduce your water pressure to 50psi? Eighty psi is perfect in my book.
    However, if you go ahead and install a PRV, you should install an expansion tank as well.
    STEVEusaPAIronmanIntplm.BillyO
  • PerryHolzman
    PerryHolzman Member Posts: 236
    I'd disagree on the comment that Propress is "Tried and True."
    It's only been around for I believe 21 years.
    Copper tubing with soldered fittings is tried and true. I'm not sure how long it has been in use. A little internet research said that it became dominant in home construction use in the 1940s'.
    I have 65 year old soldered copper in my house, and during the installation of a water softer and creating an new soft cold water header I had to cut into some of it - it was in fantastic condition.
    How long are those O-rings going to last? Who knows. I've spent much of my life in industrial plants and Power Plants and while the correct materials for O-ring applications do last a long time. I'm not sure that I have seen many that lasted over 40 years, and problems clearly develop once past 30 years. Of course, if the O-ring material is wrong... failure will be much quicker.
    I'd hate to have to open up walls due to leaking fittings in the future (not to mention how the water damage until they are discovered and fixed).
    My personal opinion: Anything inside of walls should be soldered. In open areas of the basement and utility rooms where future service would be easy I can see the use of Propress.
    I personally think there should be a noticably long stub in the open area before the Propress fitting is installed - allowing for its future replacement (perhaps more than once). Thus, you might see a soldered 90 degree elbow clear of the wall or floor (which would be a good visual that what's inside the walls is soldered).
    I see no issue with using it to construct the near boiler piping on a radiant heating system, as the boilers are likely to need replacing before the O-rings degrade.
    Perry
    BillyODan FoleySTEVEusaPAB_Sloane
  • Intplm.
    You may know that propress has been used in Europe and in other part of the world long before it came to the U.S..
    My tried and true comment derives from that knowledge.
    BillyODan FoleySTEVEusaPAGrallert
  • PerryHolzman
    The best information I can find is that Conex Banninger started to develop press fittings in Europe in the 1980's and by their own admission that things did not really get going until the 1990's; and they only claimed in 2019 to have only been producing press fittings for over 30 years (not 35, not 40, etc).
    Here's their own summary statements on this in their 2019 history video
    https://www.youtube.com/watch?v=FtOihpFHli4
    So, they realistically Europe perhaps has about a 10+ year head-start.
    My experience in Industrial and Power plants says the o-rings start failing in the 30-40 year range... which is not to say that in certain situations that they may last longer.
    I'll again repeat that I personally don't believe they are suitable for use inside walls for standard construction.
    But, again so much these days is about lowest initial cost and who currently cares about the long term. "not my problem" if it fails down the road and is very expensive to fix or replace.
    I wish you all well with this.
    Perry
    BillyO
  • ratio
    ratio Member Posts: 4,026
    I'm not sure that a 40+ year life expectancy is a strict requirement any more. At least, I can't see the new builds we have going on not going through a walls-off remodel or a gut-rehab in that time frame…
    BillyO
