A new take on two-pipe steam
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,689
The Anti-gravity System
Retired and loving it.
    EBEBRATT-Ed Member Posts: 19,804
    HAHA, that's not steam, that's a water hammer system.
    They must have looked at the blueprint upside down
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,520
    Maybe steam comes in through trap side. Obviously won't get very much heat that way. Looks like an early April fools joke. @DanHolohan. Is this radiator actually in service?
  • DanHolohan
    An engineer friend from NYC sent it to me this afternoon.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    If the trap is on the return, then it will sort of work as a 1 pipe system.
  • JUGHNE
    JUGHNE Member Posts: 11,515
    It is a quickly well vented one pipe radiator.....the supply riser looks too small to handle counter flow operation though.
    Although we do not know which side is supply or return.
    Steamhead Member Posts: 18,280
    You can't fix stupid............
    Consulting
    ethicalpaul Member Posts: 8,246
    Being so ignorant of 2 pipe steam, it took me awhile to figure out. It is that the supply should be on the high side with the return and trap on the low side, right?
    Bingo.
    Consulting
  • dopey27177
    dopey27177 Member Posts: 916
    This is not a new take on a two pipe system,
    It is a leave in in some one else's building.
    This reminds me of an upside down cake that is put out for display.
    May be this a new way to collect hot condensate and turn a steam radiator into a hot water radiator zone.
    Haha ha
    Jake
