Circulating hot water heating
augie1
Member Posts: 8
Is pointing an infrared gun on a copper line ( gas hot water boiler) a good secondary way of checking water temp in the system . A line or return line.
THANK YOU.
THANK YOU.
The infrared gun will get tripped up by the shiny copper. Putting tape on the pipe and then shooting it works pretty well. I use black electrical tape."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Ok great THANK YOU Z I appreciate it.0
Thank you much appreciated.0
I have a small can of flat black modelers spray paint I use. The flat black is the best to stop reflection. Even most electrical tape is somewhat shiny and can affect the reading.
Rick0 -
A marker does the job just fine, it's your cheapest and easiest route for sure.0
Thank you very much guys.0
a thermocouple probe is the best way to do it0
I prefer a TC clamp probe Plugged into my multimeter. Electrical tape or marker truck sounds good too.0
https://www.thermoworks.com/infrared_thermometry101_limitations_of_infraredaugie1 said:Is pointing an infrared gun on a copper line ( gas hot water boiler) a good secondary way of checking water temp in the system . A line or return line.
THANK YOU.
I use this
2 -
I have this one, mainly because of cost. They are both likely similar accuracy but the fluke can grab larger pipes.
https://www.supplyhouse.com/Fieldpiece-ATC1R-ATC1R-Pipe-Clamp-for-Refrigeration-1-8-to-3-40 -
I use this temperature head with my Fieldpiece. It allows you to use the thermistors on any surface or any size pipe. Some pipe insulation and a zip tie works well.Bob "hot rod" Rohr
Living the hydronic dream0
