Leaky Steam Raditor
Manny7
Member Posts: 16
Any advice how to temporarily fix leaky seam radiator by the joint between the radiator and valve. Is soldering the only option? Thanks in advance for any advice.
Soldering wouldn't be on the list at all. Need pictures to see where the leak is to be able to answer.0
Thanks KC_Jones. Understood. Will post post pics this evening.0
Please find attached pics showing with the water is leaking.0
Thank you mroberts5 and NBC.0
I have had good results by cleaning the mating surfaces with a very fine steel wool (000 or 0000), and not sand paper, and adding a thin coat of silicone sealant that you can buy in a tube at a hardware store or auto parts. Then see if you can find anyone that has an 18" or 24" crescent wrench you could borrow to tighten the union nut. If you have to use a pipe wrench, keep the jaws loose so as not to distort or bend the nut.0
Open it, lightly sand and Never Seize the mating surfaces and threads.0
Thanks for the additional tips retiredguy and pecmsg.0
Hello folks, So i was finally able to borrow the correct wrench and following the advice on this thread. It did not fix the leak. I am going to try again, failing that would the next option be to replace the valve? Thanks0
When you take the Union nut off again, feel the mating surfaces to see if any foreign matter, or scratches/gouges are on them, as the seal is metal face to metal face, with only a bit of dish washing soap for lubrication.
Is the valve fully open?—nbc0 -
Hi nbc, will do. The valve is fully open when the system is on. I closed it when working to try and fix the leak.0
Plus, when you go to mate the spud and the valve halves of the union again, make sure that the horizontal and vertical and angular alignment of the two pieces are as close to perfect as you can make them. Unions aren't meant to take up misalignment in any direction. Don't use torqueing the nut to try to pull the halves together! Generally they should make up by turning the nut on hand tight, and then should need no more than a quarter to half a turn on the nut to seal up. If not, it suggests that the parts or misaligned or the sealing faces are damaged.nicholas bonham-carter said:When you take the Union nut off again, feel the mating surfaces to see if any foreign matter, or scratches/gouges are on them, as the seal is metal face to metal face, with only a bit of dish washing soap for lubrication.
Is the valve fully open?—nbcBr. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 120 Geothermal
- 396 Solar
