Regulator Freezing
pachour
Member Posts: 1
I have a small LP Firepit that I normally run with a typical 5 gal portable tank. I got a 10 gal tank at a garage sale that was half full and used that on the firepit with no issues. When the 10 gal tank ran out, I had it refilled at my usual vendor. When I connected it to the firepit, the regulator and hose became completely frozen within a matter of minutes. The 10 gal tank has an OPD valve. In some of my researching I have come across suggestions that it could be anything from the tank being overfilled to their being water in the tank although most of these were related to large residential tanks. I would like to know if the causes found apply to my small portable tank as it is odd that it worked fine when it was half full.
how is it freezing? is the outside of it icing or is it freezing in the fitting or regulator and blocking flow?0
I would guess the OPD failed and the tank is slugged full. Use caution with this.. please0
Could be some moisture in it. Propane atcs like refrigerant. When it goes through the regulator the pressure drop cause a temperature drop in the propane which could freeze moisture.
The propane companies can put stuff in the tank to absorb moisture0 -
Actually it is a refrigerant. Actually a very good one except for that annoying flammability issue. R290. Making a comeback in small critically charged systems.0 -
@mikeg2015
Your right!! I keep forgetting that propane is R290. They use it on small kitchen equipment I think.0 -
Yes, small kitchen equipment... thats factory sealed with no service port to even check pressures. I think the limit is like 12 or 16 oz total charge. Guess that limits the size of the fireball.
Yeah....kitchen equipment with propane (R290) refrigerant.... environmentally friendly until the fire.
Joking aside, LP is an excellent refrigerant. Is cheap, and runs at nice low pressures. It's just that pesky flammability thing....Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
When i saw this i assumed someone being cheap charged the fridge with a hydrocarbon blend, but it was just his mom extracting oil from pot with butane indoors:
https://www.mlive.com/news/kalamazoo/2019/08/teen-burned-badly-in-butane-explosion-needs-life-changing-surgery.html0 -
If any of you watch Utube videos "HVCAR Videos" is pretty good had some interesting videos on R2900
Are you certain it is the regulator.
Butane is often mixed with propane as a cost saving measure, and butane will not vaporize below 32F (0C).
In the south, some vendors sell butane but call it propane. Disconnect the tank, bring it into a warm place for 24 hrs and try it again.0
