If you've found help here, check back in to let us know how everything worked out.
It's a great way to thank those who helped you.
Dhw circ pump replace or repair?
CBRobCBRob Member Posts: 163
This taco pump is making a racket now.
Was looking at replacements, looks like you can put a new motor in and save the housing?
What would you do? Replace the whole thing or replace the motor?
It was also installed in the vertical position. I flipped the picture over just for reading.
I think I read somewhere here on this forum that these small pumps are the exception to the rule of always having to be mounted with the shaft sideways.
If I do replace it I'll certainly put it in side ways.
I also think this pump may be a little fast for this particular application.
I've got another home just like this one where the 90 right after the pump developed a pinhole leak, perhaps cavitation?
If I replace do you have a favorite model of circ pump for this application? Three story 3000 square foot home?
  • hot_rodhot_rod Member Posts: 12,898
    get one of the new smart, ECM types, save power and add features
    The magic is in hydronics, and hydronics is in me
    CBRobdelta T
  • SteveSanSteveSan Member Posts: 48
    Please call into Taco Tech Support at 401-942-8000. We are here from 8am-5pm EST. You always can replace the cartridge or we can go over some options for a new recirc. pump.
    CBRob
  • unclejohnunclejohn Member Posts: 1,494
    Replace and install as manufacture says.
    CBRob
    keep in mind that is probably a leaded brass body, time to upgrade to stainless :)
    CBRob
  • retiredguyretiredguy Member Posts: 186
    edited January 21
    Just to compare; the recirc pump I installed in my home (4000 sq ft and 3.5 bathrooms) is a B&G bronze, modelNBF-8S rated at .39 amps, the smallest pump they had, and it works great. I was afraid that the flow even with this small pump would be too much so I made a 1/4" orfice and installed it in the discharge of the pump.I also installed it with a cheap timer so the run time is 15 minutes each hour, with extended run times in the morning and evening. Mine has run perfectly for 15+ years.
  • ZmanZman Member Posts: 5,603
    If it is mounted incorrectly to begin with, I would suggest replacing the whole thing. Constant circ models like that waste electricity and eventually wear out your pipes.
    Something along these lines would work well.
    http://www.tacocomfort.com/products/systems/instant_hot_water/smartplus/index.html
    Albert Einstein
  • MikeL_2MikeL_2 Member Posts: 236
    edited January 21
    We prefer to install dhw recirculating pumps wired in series with a timer and strap on aquastat. Typically, the timer is set for a morning run time, and an evening run time. We also like to insulate all water piping.
    CBRob
  • CBRobCBRob Member Posts: 163
    Double checked the install instructions.
    This pump is ok to be vertical as long as it is over 20 psi.
    Supply house has a cartridge for 100.00
    A new pump is over 300.00
    Expensive little pump.
    Plenty of options, brands and sizes if you want a basic small recirc pump.
    Add a lamp timer and or thermostat to limit run times and heat loss, as @MikeL mentioned.
    Is the piping insulated? If not a timer would cut down on the cost of the heat loss and motor consumption.
    SuperTech
  • Larry WeingartenLarry Weingarten Member Posts: 1,714
    Hi, I’ll add that another control choice is “demand control”. It’s available from different sources, but is far and away the most energy efficient option. It can be activated with a button or motion sensor.
    Yours, Larry
    CBRob
Sign In or Register to comment.
It looks like you're new here. If you want to get involved, click one of these buttons!
