Dhw circ pump replace or repair?
CBRob
Member Posts: 273
This taco pump is making a racket now.
Was looking at replacements, looks like you can put a new motor in and save the housing?
What would you do? Replace the whole thing or replace the motor?
It was also installed in the vertical position. I flipped the picture over just for reading.
I think I read somewhere here on this forum that these small pumps are the exception to the rule of always having to be mounted with the shaft sideways.
If I do replace it I'll certainly put it in side ways.
I also think this pump may be a little fast for this particular application.
I've got another home just like this one where the 90 right after the pump developed a pinhole leak, perhaps cavitation?
If I replace do you have a favorite model of circ pump for this application? Three story 3000 square foot home?
Just to compare; the recirc pump I installed in my home (4000 sq ft and 3.5 bathrooms) is a B&G bronze, modelNBF-8S rated at .39 amps, the smallest pump they had, and it works great. I was afraid that the flow even with this small pump would be too much so I made a 1/4" orfice and installed it in the discharge of the pump.I also installed it with a cheap timer so the run time is 15 minutes each hour, with extended run times in the morning and evening. Mine has run perfectly for 15+ years.0
If it is mounted incorrectly to begin with, I would suggest replacing the whole thing. Constant circ models like that waste electricity and eventually wear out your pipes.
Something along these lines would work well.
http://www.tacocomfort.com/products/systems/instant_hot_water/smartplus/index.html"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Double checked the install instructions.
This pump is ok to be vertical as long as it is over 20 psi.
Supply house has a cartridge for 100.00
A new pump is over 300.00
Expensive little pump.0 -
Plenty of options, brands and sizes if you want a basic small recirc pump.
Add a lamp timer and or thermostat to limit run times and heat loss, as @MikeL mentioned.
Is the piping insulated? If not a timer would cut down on the cost of the heat loss and motor consumption.Bob "hot rod" Rohr
Living the hydronic dream1 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
