water meter for make-up water steam boiler
t hardy
Member Posts: 29
Use a VXT auto feeder. Even if you don't use the auto-feed function, you can have it track the gallons added manually. Or @Gordo will correct me if I'm mistaken!
https://www.supplyhouse.com/Hydrolevel-VXT-24V-Automatic-Water-Feeder-24V-10669000-p?utm_source=HeatingHelpNJ Steam Homeowner.
thanks - this is for my new Burnham megasteam boiler which is using a working MD auto feeder - just want something to stick in line with that - to spot minor leaks/problems early
I always recommended a water meter on the make-up line for any steam boiler that was on an older steam system. My thought was that the meter was a good indicator of the integrity of the whole system especially the piping. Many times we would get a phone call from a customer saying that his system was using more water than normal and that a leak was suspected or something needed serviced.0
I am using an EKM remote-read meter. It stores two years of usage data and has been instrumental in efforts to repair leaks. It pushes to a remote server (not for everyone.....) but has local data storage options. It is overkill for single-family residential, but great for larger systems.
Photo is a screenshot of two years’ data as of today, 5 minutes ago. It is nice seeing only a few quarts a week rather than how last year looked!
For your situation, it seems like you want a good ‘ol nutating disc water meter (a small version of what cities use for water service). They are inexpensive but require manual reading to catch problems.0 -
I was able to obtain used 3/4" water meters from our utility as they are changing to WIFI reading with new meters.
I tested the flow into 5 gallon buckets and found them to be accurate. They will read as low as one gallon on the large needle.
They can be checked during blow down for needle advancement to insure they are working.0 -
I put on a cheap meter from Amazon. The numbers are even English numerals and units are gallons. I think it was $40 or less.
It works. I put it downstream of both the manual and auto feeders.0 -
Can you show us which one you used?mikeg2015 said:I put on a cheap meter from Amazon. The numbers are even English numerals and units are gallons. I think it was $40 or less.
It works. I put it downstream of both the manual and auto feeders.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I would like to use a VXT hydrolevel meter to track usage but want to keep my existing MD feeder - has anyone done this?
thanks much0
- 116 Geothermal
- 15.8K Strictly Steam
