Can steam risers expand within a sleeve of pipe insulation?
VictoriaQ
Member Posts: 2
The pipe insulation sleeves are denser than i thought. Is it okay if the pipe insulation sleeve fits snugly between a steam riser and the adjacent wall? Will the steam riser still be able to expand as it needs to within the sleeve of insulation or should there be a gap between the sleeve of insulation and the wall?
No to worry. The pipe will expand very happily -- the fit of the insulation is nowhere near good enough to prevent that!Br. Jamie, osb
And the pipes don't expand measurably in that direction
Thanks so much!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
