Can steam risers expand within a sleeve of pipe insulation?
The pipe insulation sleeves are denser than i thought. Is it okay if the pipe insulation sleeve fits snugly between a steam riser and the adjacent wall? Will the steam riser still be able to expand as it needs to within the sleeve of insulation or should there be a gap between the sleeve of insulation and the wall?
    Jamie Hall Member Posts: 27,397
    No to worry. The pipe will expand very happily -- the fit of the insulation is nowhere near good enough to prevent that!
    ethicalpaul Member Posts: 8,868
    And the pipes don't expand measurably in that direction
  • VictoriaQ
    VictoriaQ Member Posts: 2
    Thanks so much!
