Steamer Replacement
EzzyT
Member Posts: 1,379
We ripped out out this leaking Bryant boiler.
Installed a Peerless 63-05 with 4” drop header.
It was a tight squeeze between the two water heaters. We also upgraded the main venting with Barnes & Jones Big Mouth Vents.
Big thanks to Rob Calmbacher (Clammy) for helping us out on this one.
3
Nice job, tight fit!!! I suppose the RH water heater could be moved over if need be. Looks like you can get at everything though!0
@EBEBRATT-Ed thanks.
Yes it will be moved when it is time to replace it and there is room to get to everything.0 -
Excellent work, as always.Bob Boan
Thanks to you and Fred always a pleasure to work w those who are always prepared and have the right plan to do things correctly and do it .it really didn’t seem that tight but then again when ur working w a goal and plan we all tend to get tunnel vision which in some cases it’s better to have tunnel vision then to look around when working in dark tight spaces .again always a pleasure to spin along side you and Fred ,both are truely craftsman’s and as all can see professionals of there chosen profession and of course a great work ethic which is far and few between now a days Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 50 Industry Classes
