Steamer Replacement
    EBEBRATT-Ed Member Posts: 20,312
    Nice job, tight fit!!! I suppose the RH water heater could be moved over if need be. Looks like you can get at everything though!
  • EzzyT
    EzzyT Member Posts: 1,380
    @EBEBRATT-Ed thanks.
    Yes it will be moved when it is time to replace it and there is room to get to everything.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • Ironman
    Ironman Member Posts: 7,906
    Excellent work, as always.
    Bob Boan
  • EzzyT
    @Ironman thanks.
    201-887-8856
  • clammy
    clammy Member Posts: 3,256
    edited January 2020
    Thanks to you and Fred always a pleasure to work w those who are always prepared and have the right plan to do things correctly and do it .it really didn’t seem that tight but then again when ur working w a goal and plan we all tend to get tunnel vision which in some cases it’s better to have tunnel vision then to look around when working in dark tight spaces .again always a pleasure to spin along side you and Fred ,both are truely craftsman’s and as all can see professionals of there chosen profession and of course a great work ethic which is far and few between now a days Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
