Propane TT PS 60 E02
Rich Davis_2
Rich Davis_2 Member Posts: 128
About 2 months ago my TT PS60 started having hard lockout on E02, not lighting. I pulled the ignitor and went ahead and serviced the boiler. The ignitor looked fine but I cleaned the electrodes with a fine file anyway. In the last couple days it's doing it again I haven't pulled the ignitor yet and I've went ahead and ordered a new ignitor. I didn't have a combustion test done yet. I installed this boiler about 2012 and never had any problems with it. Does anyone have any suggestions. Also when I reset it it will try to lite once and then always on the 2nd try it fires fine.
  • Ironman
    Ironman Member Posts: 7,903
    You should only use a dollar bill to clean the electrodes.
    Without first establishing that the combustion numbers are correct, it's a guessing game after that, not a diagnosis.
    Have you checked to make sure the condensate line is clear including the collector at the bottom of the heat exchanger?
    Bob Boan
  • lchmb
    lchmb Member Posts: 2,997
    Has it ever had a proper service done?
  • Rich Davis_2
    Yes 2 years ago.
    I went to the TT school in 2010.
  • Rich Davis_2
    Well the problem is back. I had combustion check done every thing is in spec, checked the propane press 9-10"WC good, replaced igniter ran fine for about 3-4 weeks now it's tripping about once a day. Any other suggestions? Thanks
  • Zman
    Zman Member Posts: 7,609
    What were the combustion numbers? High and low?
    Albert Einstein
    Ironman
  • DZoro
    DZoro Member Posts: 1,048
    Operating gas pressure?
    Have you cleaned the burner side of the H/E?
    How is the light off? rough? delayed?
    How does the venturi look? any black dust inside?
    D
  • psb75
    psb75 Member Posts: 1,129
    Any follow up from original poster on this? I have a TT PS60 and remain interested.
  • Ironman
    Check all of your electrical connections, particularly the ground. It must be solid all the way from the burner back to the electric panel.
    Bob Boan
