IR temp gun
adamt
adamt Member Posts: 16
Hello all, any recommendations on an IR temp gun? I heard they might not work well on shiny copper pipes due to reflection. Is there a better way to measure the water temp on a zone without a pre-installed gauge?
    EBEBRATT-Ed Member Posts: 19,398
    You can use an electronic thermometer with a probe (Fluke 51/52) or some electrical testers have a temperature setting.
    spray painting the copper black will work with an IR gun
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,991
    Hello, I like the FLIR One and paint or tape on new copper will help.
    Yours, Larry
    ratioJohnNY
    Jamie Hall Member Posts: 26,757
    Electrician's tape wrapped around the pipe works fine.
    steamedchicago
  • ratio
    ratio Member Posts: 4,172
    @Larry Weingarten's got it with the FLIR ONE and tape. I've got the ONE Pro and it's got a great picture. The image overlay works good too. (NB: I don't have a $50k model to compare it with.) Attached is a pic from mine, to give you an idea of what you can expect.
    hot_rod Member Posts: 26,464
    30 bucks buys a good temperature gun
    Flat black marker or friction tape, nothing shiny
    rick in Alaska
  • Gordy
    Gordy Member Posts: 9,546
    edited December 2019
    Keep in mind the aspect ratio when using.
    You need to be right up close to the target.
  • ChrisJ
    ChrisJ Member Posts: 17,047
    And the IR gun needs to be stabilized at the room temperature otherwise it'll drift as it changes.
  • adamt
    Thank you for all of the comments and feedback.
    HVACNUT Member Posts: 7,190
    I guess IR has its place but I'll always use a clamp on. I can capture with it too.
