copper made heating Tank
unconventional
unconventional Member Posts: 1
I am a new heat engineering student. My questions are:
1) In a fire-tube boiler, why copper is not used for furnace body and smoke pipes inside the boiler? Copper is x15 time more thermal conductive.
2) Doesn't Iron pipe/ heating tank/ furnace need more fuel to heat up (for low thermal conductivity) and keep at high temperature?
    Jamie Hall Member Posts: 26,993
    Copper used to be, years ago -- but it isn't strong enough for power boilers, it work hardens and fatigue cracks, and it is at least as prone to corrosion as black iron or some (not all) steels.
    And on the second one, yes, on initial firing the mass of metal is somewhat significant, and does take a little more fuel to heat. However, the differences in thermal conductivity are not large enough -- though they are certainly significant -- to overcome the strength problems (which would require much thicker copper).
    Solid_Fuel_ManSuperTech
    hot_rod Member Posts: 27,056
    Copper fin tube boilers are still very common. Water in the tube, finned outer takes the heat from the burner. Raypak, Laars, RBI, and Lochinvar are the main brands.
    Copper is an excellent metal for heat exchange.
    EBEBRATT-Ed Member Posts: 19,881
    Copper expands too much to use in normal designed boilers. Used in the boilers @hot_rod mentioned above is fine. They are basically a hot water coil
    pecmsg Member Posts: 6,877
    MONEY!
    delcrossv
  • ChrisJ
    ChrisJ Member Posts: 17,145
    How about Monel?
  • delcrossv
    delcrossv Member Posts: 2,189
  • ChrisJ
    delcrossv
