Heat expansion noise
gfrbrookline
Member Posts: 753
I raised a problem radiator about 1/4" on the supply side and 1/2" on the vent side. I no longer have water hammers but now have knocking sounds coming from the pipes.
Do the joints need time to settle out to the new radiator height? Haven't had this issue before when I raised radiators to correct pitch of either radiators or run outs.
Maybe the slope problem or “valley” got moved and you’re hearing water hammer farther down the pipe.
Or your work increased tension (removed free play) in the pipe and it is expansion noise.
Is this an upstairs radiator or can you listen/observe in the basement?NJ Steam Homeowner.
In addition to water hammer somewhere new it could be that it is now binding against a hole in the framing and sticking ans slipping as it expands and contracts. Depends on the sound of the "knock".0
Lower it a1/4” and see what happens.0
@pecmsg that's what I did and it fixed the problem. Good call.0
I used plywood strips about 1-1/2" wide (adjust length to fit radiator depths), they are cheap and can be stained so they don't swear at the floor. You can use different thicknesses to correct slope issues.
3PSI gauge0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
