Steam Mystery
I agree with @Steamhead gate valve stripped out and dropped gate. Closing the valve in the parrallel flow zone cause the boiler to build pressure and forced water up through the drip and out the open tee0
Has to be a bad King Valve on the counter flow side, failed closed, and when they closed the king valve on the parallel flow side, boiler pressure pushed water back through the drip and down the main.0
It was already solved guys. @Fred , @EBEBRATT-Ed . Happy THANKSGIVING!Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Happy Holiday to you too, @Charlie from wmass !Charlie from wmass said:It was already solved guys. @Fred , @EBEBRATT-Ed . Happy THANKSGIVING!
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
