Ghosts closing radiator valves ;)
tomsloancamp
Member Posts: 89
Has anyone experience radiator valves closing on their own? On several occasions, I have found the valves to be turned down to near close and I’m pretty sure my wife isn’t doing it.
"pretty sure"
How easily do these turn?
Are they leaking at the packing nuts?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The posts aren’t loose but it seem to have happen on 2. I recently got a new boiler installed and the had hammering issues (which were resolved through skimming.) The gaskets under the nut are indeed worn so I am in the process of replacing them with graphite packing. They were fully closed so I wonder if the vibration from the hammering could have caused it (they were on the same riser.)0
Perhaps a donation to the sisters, and a request for prayer would help.
https://forum.heatinghelp.com/discussion/171801/please-help-the-franciscan-sisters-of-kansas-city-with-their-boiler#latest3 -
I find it very difficult to imagine that the valves are being closed by vibrations. Most radiator valves require more than several complete turns to close from full open. As I said, difficult to imagine them closing by themselves. It is possible I suppose the disks have worked loose by vibration and fallen into the close position, but then you wouldn't be able to open them with the hand wheel again either.1
I've seen that before in a home by a heavily trafficed road and across from a Railroad. One or two valves would gradually close. tightening up the packing will help provide some resistance to keep it from turning closed.To learn more about this professional, click here to visit their ad in Find A Contractor.1
@mattmia2 here’s a pic of the valve ... I started repacking them and I haven’t seen an sign of ghost or gremlins. I did find some condensation leaking from the stem before repacking.0
Yes. I have had this happen before.
The family pet rubbing against the valve. And or.
The packing nut is loose and the valve is not backseated all the way can also do this. (That's tightly turned all the way to the on position.)
So check those things first before considering hiring an exorcist.😇0 -
Is the knob by any chance rubbing against the wall and turning as the pipes and radiator expand and contract?
BTW it is a rising stem globe valve so it has relatively coarse threads that probably aren't stripped and dropping somehow.0 -
I don't think the wife will give up the answer to that question! Or is that two different unrelated questions?Fred said:Have you asked your wife? Who else lives in the house?
tighten up the packing nut. Put a baby monitor pointed at the offending radiators and see what happens.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron1 -
I once had an issue where a manufacturer shipped a threaded insert in the fully open position. They kept coming in closed. I thought that the truck bouncing around was doing it. So I laid one on the counter and put a vibrator under the counter. Sure enough the threaded insert turned down, because its an inclined plane. If the valves really loosy goosy, the water hammer may be causing that. maybe tighten the packing nut0
- 50 Industry Classes
