What is this Thrush component?
Single pipe connect at bottom
    EBEBRATT-Ed Posts: 20,947
    looks like an expansion tank
    hot_rod Posts: 28,209
    It does have an old steel compression/expansion tank above.
  • EzzyT
    EzzyT Posts: 1,380
    Maybe used to add more mass to the system like a reservoir tank.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • ScottSecor
    ScottSecor Posts: 1,055
    @hot_rod where does the supply pipe come from on the boiler? I notice the circulators are pointing upwards, but I can't see how they get fed. Is that a bleeder facing us on the Thrush tank?
  • Good eye, Scott. It looks like the supply comes out of the boiler, goes into the Thrush device and the comes out the back to feed the circulators.
    It's a pass-through expansion tank!
  • Ironman
    Ironman Posts: 7,942
    I've seen pass through compression tanks like that which had baffles to separate the air, but if there's a tank above, I can't see what function that would have.
    Maybe @DanHolohan would know?
    Bob Boan
  • Ironman
    Does it have a number on it?
    Bob Boan
  • DanHolohan
    DanHolohan Posts: 16,732
    I’ve seen those. Combo air separator/compression tank. A product that didn’t live up to its hype.
    Retired and loving it.
  • Big Ed_4
    Big Ed_4 Posts: 3,569
    I am surprised the last installer reinstalled it... I was impressed with Thrush equipment , well made ...
