Removing a 2' section of CI baseboard cleanly
Is it an end or middle section? A middle section will have push nipples on both sides. And end will have threaded connections on one side. If it's the end section, you'll need a new one. You'll also need new push nipples and the assembly tool. Don't attempt to do it without the tool!Bob Boan
Section next to the end. Want to reuse the end, and just pipe it without replacing the bad section. How to separate after 50 years. Assembly tool? Lots of fin tube, no cast experience.0
Gently, like any radiator where you're trying to save it.michaelj1 said:Section next to the end. Want to reuse the end, and just pipe it without replacing the bad section. How to separate after 50 years. Assembly tool? Lots of fin tube, no cast experience.
Get new push nipples.
Bob Boan
You want to just run a pipe in between where the broken section was? Um... reread @Ironman 's comment. Those sections are joined with push nipples, not threaded joints. While I expect something could be MacGyvered to do the job, it's going to be custom machining... You'll be better off to take that section out and shift the good end section over with new push nipples and tension rods, and run a new pipe from the inlet (or outlet) pipe to where the end section sits now.Br. Jamie, osb
