Looking for a new oil boiler (I heat my radiators with steam)
georgede54
Member Posts: 55
I'm probably going to be buying a new oil boiler. Is there any independent rating source, or other place, that would help me to compare the enormous number of models that are on the market.
The usual mantra from professionals on this site:
1. The installer is more important than the boiler.
2. In the case of steam, boiler sized to the edr of the connected radiation..
There really isn't any true independent ratings source. Most of the bad reviews are going to be from:
1. Wrong size boiler.
2. Improper piping/installation.
3. In the case of steam, incorrect near boiler piping, and improper venting.
In general, with oil, I like to avoid pinners, as they almost never get cleaned properly. But there may not be too many options.
Where are you located?
There are some master steam guru's here with a lot of experience with all the major boilers.
There are also many wonderful examples of their work on this site.There was an error rendering this rich post.
2 -
As @STEVEusaPA says, a boiler isn't a refrigerator or a washing machine. It's part of the whole system which heats your house, and it must be sized properly (as he says, to the radiation) and installed properly -- and the latter part of the equation is at least 90 percent of the success or failure of the job -- and a sizeable chunk of the efficiency and longevity.
Some folks like one make or type of boiler better, others like others better. Sort of like some folks like Chevys, and some like Fords.
Find a good installer whom you can trust (as @STEVEusaPA says, there are a number who are on this site) and work with them.Br. Jamie, osb
This. Also, Crown has a version of the same boiler- the Freeport 2/FSZ.Ironman said:For oil fired steam, I would only use the Burnham MegaSteam.
Consulting2 -
Thanks for the input!0
So @georgede54 , how did it work out?All Steamed Up, Inc.
Consulting0 -
I'm still plugging away. I've started to measure the radiators and do the computations. I've posted some pictures under my "Sizing a new boiler" discussion, if you want to take a look.
The radiator in the living room, which I believe is a column type, is 25.5 inches high x 7 inches wide.
The radiator in the kitchen, which I believe is a tube type, is about 26" high.
I think I know what is needed for people to be able to compute the EDR from the pictures, so I should be posting more in a few days.
Thanks again.
Thanks. I'm not sure what is meant by "depth of section." How do I measure that?0
Is the "depth" what I might call the width?0
Depth is front to back, i.e. the side facing into the room to the side facing the wall.georgede54 said:Is the "depth" what I might call the width?
Since there are many different types of radiators, it would help if you took pics and posted them here, so we could see what you're talking about.All Steamed Up, Inc.
Consulting1 -
Thanks to one and all.0
I have just posted the information and pictures necessary to compute the EDRs for my upstairs radiators in a new discussion titled "Computing the EDRs of My House Radiators for a New Oil-fired Steam Boiler." If you want to take a look and run the numbers, I'd appreciate your efforts. Thanks.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
