Commercial Steam Boiler Replacement plumber recommendations? NYC/LES area
nybigapple
Member Posts: 61
I have an old steam system that is quickly deteriorating for a 28 unit 2 apartment building setup. The boiler is a weil mclain lgb 9. We recently discovered leaking in the boiler, and I believe it is definitely time for a replacement. This is an old tenement where the heating system has seen little to no maintenance and in the last few years, the water hammer has caused steam pipes to start bursting and need emergency patching. So I'd like a plumber who can first replace the boiler and redo the near boiler piping. I placed a picture of the boiler a couple of years ago and was told I would highly benefit from a drop header. Second, I need a plumber who can address the water hammer.
I have a local master plumber who I've used a few times and is all too eager to replace the boiler for a hefty sum, but doesn't seem very knowledgable or willing to address the system as a whole. When I inquired about what he would do he wanted to reuse as much existing piping as he can and just insert a new boiler which threw up the warning signals.
I'm right here. My installations are done through my larger company, Gateway Plumbing & Heating.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Try @JohnNY (John Cataneo, Gateway Plumbing & Heating, 212-980-0909 or (646) 598-7230). About the best out there...Br. Jamie, osb
@nybigapple your instincts are correct when you mention addressing "the system as a whole" and also getting rid of the water hammer. The system, (and) changing the boiler must be done correctly or you will be buying a new boiler with the same problems you are having now. And there is no sense in that.
Get a second opinion from a local and reputable company that will be there for you over time. The advice given above is well worth following.0 -
> @SeanBeans said:
> @JohnNY were you ever contacted to check out this job?
Yes I was. It’s a special case. November isn’t the time to get into it. It needs too much attention and time.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
