Floating balls on boiler feed water? Ever heard of that?
I was reading a book from Spirax Sarco and it recommended using floating balls in the boiler feed unit to limit the oxygen during long off times like you would see in a brewery. The balls act like a blanket system. It said it will limit the O2 scavenger needed in system. Never heard that before and wanted to see if you ever did.
Thanks
Ray
Ray Wohlfarth
Boiler Lessons
