Boiler Room
Member Posts: 4,698
This is in the mechanical room of a house that had an extensive remodel six years ago with a permit, passed by the inspector.
And these were the B & G pumps, wired for 110 volts each.
Was the inspector on the same drugs as the moron who installed the boiler?All Steamed Up, Inc.
Consulting0 -
Gross.0
You'd think that with all the times an inspector has cited 'workmanship' to push his pet peeves into the code, he'd remember that section of the code when he saw this.0
I particularly liked the on-demand venting directly into the boiler room.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
How well did that 230V pump motor fair connected to 115V?0
Yes.STEVEusaPA said:Is all that flex pipe due to you being in an earthquake zone?
I'd say the motor spun, but I can't say how much water it moved. The owner said the system was tepid at best.JUGHNE said:How well did that 230V pump motor fair connected to 115V?
He also was smart enough to realize that his system was a "Builders Special". The GC installed it and by the time he trimmed out the boiler room, he was running out of money. The PEX was non-barrier. Those pumps were bronze - $$$, but I'd say he probably had them laying around from a previous job.
We're replacing the Bosch with an IBC, model SL. I think he'll notice a difference.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1
