Floating balls on boiler feed water? Ever heard of that?
RayWohlfarth
Member Posts: 1,813
I was reading a book from Spirax Sarco and it recommended using floating balls in the boiler feed unit to limit the oxygen during long off times like you would see in a brewery. The balls act like a blanket system. It said it will limit the O2 scavenger needed in system. Never heard that before and wanted to see if you ever did.
Thanks
Ray
Thanks
Ray
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
I've heard of it, @RayWohlfarth , but never seen it. No good reason why it wouldn't help, at least a bit. Also cut down on evaporation from the feed tank, if it's hot.Br. Jamie, osb
They do that in the reservoirs in the LA area. Not super pertinent, but interesting nonetheless.
https://m.youtube.com/watch?v=uxPdPpi5W4o
Homeowner from Providence, RI
Home b. 1897, one-pipe steam with a indirect gravity hot air system using Gold's pin radiators.0 -
Could not the floating balls potentially block the boiler feed tank vent or overflow?0
@jsavage I heard they work great to lower the odors
@EBEBRATT-Ed Good point never thought about thatRay Wohlfarth
Boiler Lessons0 -
use big enough ones...EBEBRATT-Ed said:Could not the floating balls potentially block the boiler feed tank vent or overflow?
Interesting video. The math suggests they paid $32,000,000 for the balls though. Seems like a very pricey solution.jsavage said:They do that in the reservoirs in the LA area. Not super pertinent, but interesting nonetheless.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Newark received $60 million from the EPA to cover the Cedar Grove NJ reservoir with some unknown solutionJohnNY said:
It requires thinking and forethought but venting can be eliminated. What's the good of expelling air and then letting it back in?0
I have to say that is a fascinating video jsavage
gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
