AK recommendation?
Pointbock
Member Posts: 3
Hi All,
Mostly this starts with the need for a new roof. To eliminate one more roof penetration and to up the efficiency of our heating (home and water,) we're in the market for a modcon and indirect water heater, unless someone can convince me other wise. (I don't think a combi is the right thing for us.)
Current situation: ~1800 sq ft, 2 story, just north of Anchorage, 70K 80% WM boiler (NG,) and a separate 50gal water heater (don't know why they didn't go indirect from the start,) tube/fin baseboard. The house was built in '96 (2x6, windows are okay) and I believe boiler and WH are original. Just two of us with typical household water needs (no big tubs, etc.)
I'm putting our heat load at 40K, so the current boiler isn't too oversized (cap 56K) but I don't know why there's a separate 50K, 50 gal water heater. I'm learning just enough to know how much I don't know, but it seems that an 80K modcon with a 10:1 turndown and a 40 gal indirect should work well for our needs. This should be a pretty easy install, two zones, room to work and easy access from the crawlspace if gas/electric/plumbing (condensate line) need to be moved/installed. We'd like to gain a little space to move a cabinet and add a laundry sink, if possible - a wall mounted boiler might help.
We have had a couple of quotes, but we asked about combi's at that time, and everything seemed so oversized (to handle water heating, I understand now.) We've liked most of the service guys that we've seen but haven't really liked any of the sales staff (not uncommon for me.)
We're looking for a good recommendation for Chugiak, AK (99567.) Eagle River, Anchorage, Wasilla, Palmer are all options. I don't think that RickinAlaska is here anymore, and the "find a Contractor" doesn't cover AK. Any good contractors to recommend, and/or product lines? I think HTP gets some love around here but closest sales contact shows as MT, though I know there are local dealers. Burnham/US Boiler?
Thanks,
Tory
Thanks,
Tory
Albert Einstein1 -
He's your man. Finest kind.Zman said:Br. Jamie, osb
What's the Design Day Temperature by you? The other guys know more but my silly question is, can a mod con give you the SWT you need on a Design Day? The few I'm familiar with top out around 190°.0
Residential heating running over 190?HVACNUT said:What's the Design Day Temperature by you? The other guys know more but my silly question is, can a mod con give you the SWT you need on a Design Day? The few I'm familiar with top out around 190°.
The only reservation I would have with a mod/con in AK would be parts and service."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Sounds like fun, and thanks for the kudos, but Homer is over 250 miles away. Big state.
To pointblock; I would get hold of either Keller supply, Ferguson, or Pacific Plumbing for contractors in your area
Rick0 -
Anchorage isn't too bad, -18 to -23 depending on the source. Fairbanks/Interior AK is a different story.HVACNUT said:What's the Design Day Temperature by you? The other guys know more but my silly question is, can a mod con give you the SWT you need on a Design Day? The few I'm familiar with top out around 190°.
Thanks Rick. (Sorry I wrote "DaninAK" in my original post - he's a guy on another forum.)rick in Alaska said:Sounds like fun, and thanks for the kudos, but Homer is over 250 miles away. Big state.
Rick
Are you still in Homer?0 -
Yes I am still in Homer, but currently in Washington for a few more days.
Rick0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
