Best Practice to unclog fuel lines
AlexMinolfo
Member Posts: 3
Hi All,
I am currently researching the standard method to unclogging fuel lines connecting heating tanks to furnaces.
Is there a best practice manual or standard for how to remove the clog?
If not, what is the typical industry solution?
Thanks,
Alex Minolfo
EDIT: See comment for clarification
Thanks,
Alex Minolfo
like to start with -- are we talking oil, natural gas, LP?Br. Jamie, osb
Hi Jamie and Tim,
I am specifically talking about the fuel pipe connecting an above ground storage tank containing #2 fuel oil to a residential heating furnace.
I apologize for the ambiguity this is my first time posting on here.
Thanks,
Alex0 -
I use the Co2 Blowout tool for this. remove the fuel line from the tank and the fuel pump. blow the crud into a waste container (carefully) and then flush the line out with clean fuel.
Agree totally with @Robert O'Brien
If you can’t unclog it with a push pull, replace it.
Also important to determine why it clogged, or even if it’s clogged. Could be pinhole in supply tube in tank.
-Bad fuel
-Dirty tank
Both would require draining/cleaning tank and/or additives.
-Filter not at tank
-Collapsed/pinched fuel line.There was an error rendering this rich post.
3 -
And no offense, but if you're researching you need to call a Pro. That is not DIY. You dont wants an "oops" with a tank full of fuel oil.0
@HVATNUT , None taken. I won't be performing any of this myself. I am simply gathering information to find a
cite-able source (i.e. manual, standard) for a report I am writing.0
