Best Practice to unclog fuel lines
AlexMinolfo
AlexMinolfo Member Posts: 3
edited August 2019 in Gas Heating
Hi All,
I am currently researching the standard method to unclogging fuel lines connecting heating tanks to furnaces.
Is there a best practice manual or standard for how to remove the clog?
If not, what is the typical industry solution?
Thanks,
Alex Minolfo
EDIT: See comment for clarification
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    Are you referring to the gas line to the equipment? You need to be more specific in describing exactly what you are talking about.
    AlexMinolfo
    Jamie Hall Member Posts: 27,519
    like to start with -- are we talking oil, natural gas, LP?
  • AlexMinolfo
    Hi Jamie and Tim,
    I am specifically talking about the fuel pipe connecting an above ground storage tank containing #2 fuel oil to a residential heating furnace.
    I apologize for the ambiguity this is my first time posting on here.
    Thanks,
    Alex
  • Jellis
    Jellis Member Posts: 232
    I use the Co2 Blowout tool for this. remove the fuel line from the tank and the fuel pump. blow the crud into a waste container (carefully) and then flush the line out with clean fuel.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,595
    NORA strongly recommends against the use of CO2 cartridges, they can develop pressures in excess of 800 PSI and can rupture copper oil lines. A hand push/pull pump is the preferred method
    STEVEusaPAHVACNUTAlexMinolfo
  • STEVEusaPA
    Agree totally with @Robert O'Brien
    If you can’t unclog it with a push pull, replace it.
    Also important to determine why it clogged, or even if it’s clogged. Could be pinhole in supply tube in tank.
    -Bad fuel
    -Dirty tank
    Both would require draining/cleaning tank and/or additives.
    -Filter not at tank
    -Collapsed/pinched fuel line.
    Robert O'BrienHVACNUTAlexMinolfo
    HVACNUT Member Posts: 7,508
    And no offense, but if you're researching you need to call a Pro. That is not DIY. You dont wants an "oops" with a tank full of fuel oil.
  • AlexMinolfo
    edited August 2019
    @HVATNUT , None taken. I won't be performing any of this myself. I am simply gathering information to find a
    cite-able source (i.e. manual, standard) for a report I am writing.
