What does this mean?
Zman
Member Posts: 7,611
I am doing some light reading in the 2018 IECC https://codes.iccsafe.org/content/IECC2018P3/chapter-4-re-residential-energy-efficiency
Does anyone know what this part of Table 405.5.2(1) means?
I keep coming up with millions of Btu/day for a 1,000 square foot home. That can't be right...
Albert Einstein
Albert Einstein
forgot what that's called .............order of...........something0
I have to admit that the way it's presented isn't perfectly clear... @STEVEusaPA 's parentheses are correct -- but it would be better if the publisher had put them in in the beginning, because @Zman 's interpretation isn't actually incorrect, considering just the way it's written, either.Br. Jamie, osb
Thanks @STEVEusaPA
I guess you need to go to the IMC before they will trust you with 8th grade algebra order of operations"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Hey, at least he knew enough to know something was wrong....
Unlike some fresh-outta-school engineers I have met.There was an error rendering this rich post.
I came up with 54,600 for my house. Which works out to be 2,277 btu's per hour.Interestingly, the formula assumes all the bedrooms are occupied to get that reading. That would have to be something to factor in if you were trying to get a very accurate heat loss of the house.
Rick0 -
I had an "AHA" moment as soon as @STEVEusaPA pointed it out. The class where I learned order of operations was more than a few years agoLuckyDog said:Hey, at least he knew enough to know something was wrong....
Unlike some fresh-outta-school engineers I have met."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I wonder how the kids solve that equation with the new style math?
"Siri whats the ansrwe"?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
