What does this mean?
Zman
Zman Member Posts: 7,611
edited July 2019 in THE MAIN WALL
I am doing some light reading in the 2018 IECC https://codes.iccsafe.org/content/IECC2018P3/chapter-4-re-residential-energy-efficiency
Does anyone know what this part of Table 405.5.2(1) means?
I keep coming up with millions of Btu/day for a 1,000 square foot home. That can't be right...
Albert Einstein
  • STEVEusaPA
    1000 sq ft and 3 bedrooms = 54012
    =17900 + (23.8 x 1000) + (4104 x 3)
    =17900 + 23800 + 12312
    =54012
    Zman
    EBEBRATT-Ed Member Posts: 19,538
    forgot what that's called .............order of...........something
    Jamie Hall Member Posts: 26,830
    I have to admit that the way it's presented isn't perfectly clear... @STEVEusaPA 's parentheses are correct -- but it would be better if the publisher had put them in in the beginning, because @Zman 's interpretation isn't actually incorrect, considering just the way it's written, either.
  • Zman
    Thanks @STEVEusaPA
    I guess you need to go to the IMC before they will trust you with 8th grade algebra order of operations :D
    Albert Einstein
    Solid_Fuel_Man
  • STEVEusaPA
    edited July 2019
    It’s actually correct the way it’s written. When no parenthesis are written, order of operations are the rule.
    Just think of a formula with no parenthesis like:
    π r^2
    You would square the radius before multiplying π.
    Zman
  • LuckyDog
    LuckyDog Member Posts: 22
    Hey, at least he knew enough to know something was wrong....
    Unlike some fresh-outta-school engineers I have met.
  • rick in Alaska
    rick in Alaska Member Posts: 1,513
    I came up with 54,600 for my house. Which works out to be 2,277 btu's per hour.Interestingly, the formula assumes all the bedrooms are occupied to get that reading. That would have to be something to factor in if you were trying to get a very accurate heat loss of the house.
    Rick
  • Zman
    I had an "AHA" moment as soon as @STEVEusaPA pointed it out. The class where I learned order of operations was more than a few years ago :)
    Albert Einstein
  • STEVEusaPA
    I wonder how the kids solve that equation with the new style math?
  • ratio
    ratio Member Posts: 4,176
    "Siri whats the ansrwe"?
