Is it a boiler, a still or?
Larry Weingarten
Larry Weingarten Member Posts: 4,006
I have a good friend living near Nashville, TN. He knows I like anything to do with hot water, so sent me this photo. I first thought coal fired hot water, but the sight glass doesn't fit that guess. But then, the name tag is sideways, which seems wrong and the upper end of the sight glass seems to be leaded in.. different from the lower port. Then there is a different name on the base than is on the tank. Any idea what's going on here? Whiskey? :D
Yours, Larry
    HVACNUT Member Posts: 7,231
    Looks like an old "Side Shot" water heater that somebody sat on top of a stoker. Either that or a first gen. meth lab. Any beakers or Pitbulls around?
  • Intplm.
    Intplm. Member Posts: 2,829
    Let's fire it up. Drinks all around !
    A still is a type of boiler.
    EBEBRATT-Ed Member Posts: 19,577
    Made by "Standard something" Made in 1955, 320 is probably square feet of heating surface, 150 is probably psi
    I think at one time it was a high pressure steam boiler
  • STEVEusaPA
    It's missing a few things to be a still...
    Jamie Hall Member Posts: 26,835
    Not that hard to add... a nice coil of copper pipe... a few fittings...
    pecmsg Member Posts: 6,770
    It would make a nice Smoker now!
  • psb75
    psb75 Member Posts: 1,100
    A little hard to get the "spent mash" out. And most stills were/are copper/stainless..
    Looks like 3 taps on top. Hot, cold, relief valve. I bet theres a nice copper coil in there.
