Is it a boiler, a still or?
Larry Weingarten
Member Posts: 4,182
I have a good friend living near Nashville, TN. He knows I like anything to do with hot water, so sent me this photo. I first thought coal fired hot water, but the sight glass doesn't fit that guess. But then, the name tag is sideways, which seems wrong and the upper end of the sight glass seems to be leaded in.. different from the lower port. Then there is a different name on the base than is on the tank. Any idea what's going on here? Whiskey?
Yours, Larry
Yours, Larry
Looks like an old "Side Shot" water heater that somebody sat on top of a stoker. Either that or a first gen. meth lab. Any beakers or Pitbulls around?0
Let's fire it up. Drinks all around !
A still is a type of boiler.0 -
Made by "Standard something" Made in 1955, 320 is probably square feet of heating surface, 150 is probably psi
I think at one time it was a high pressure steam boiler0 -
It's missing a few things to be a still...
Not that hard to add... a nice coil of copper pipe... a few fittings...STEVEusaPA said:It's missing a few things to be a still...
It would make a nice Smoker now!0
A little hard to get the "spent mash" out. And most stills were/are copper/stainless..0
Looks like 3 taps on top. Hot, cold, relief valve. I bet theres a nice copper coil in there.0
- 129 Chimneys & Flues
- 122 Geothermal
