Need a tool for lifting a radiator
ansky201
Member Posts: 1
I have a cast iron radiator that needs to be re-pitched because the block of wood that was used previously has cracked. I need a jack (or similar tool) that can fit in the 1-inch gap between the floor and the radiator to raise it up about 1 more inch so I can slide a new block of wood under it. Does anyone have any suggestions for a tool I can use?
https://www.kleintools.com/catalog/ripping-bars/grizzly-bar
I picked my car up with it when it fell off the jack. I don't know if it was this one, or one a little heavier.
Edit: I actually remember it better. My sister got a flat and was against a tall curb and I couldn't get the jack under the frame. So I used that grizzly bar with a block to lift the car so the jack could be placed in the right spot.There was an error rendering this rich post.
Cats paw and wood
@Steve Minnich I gotta tell ya. That pry truck has saved my back many times. Simple , strong and reliable with a great lineage.......must have been invented the the Egyptians , Romans or Greeks.2
all those lever type things are nice if you have room for prying. i have that win bag that Alan posted but have yet to use it. i have doubts but maybe it will work. the real fix is the cheap porta power kit and the "birds mouth" wedge attachment from harbor freight. you can get it into position anywhere, and makes a one person job out of anything. wont break the bank and comes with a zillion other attachments for the other zillion things that you didn't know you needed it for.
https://www.harborfreight.com/4-ton-Heavy-Duty-Portable-Hydraulic-Equipment-Kit-62115.html1 -
I would try something like these
http://nestorbars.com/
I’ve been wanting to get one but haven’t pulled the trigger yet just seems like it would be a handy thing to have much more stable than a standard crowbar because of the double feet allowing you to lift in a controlled fashion. Check out some of videos of the Nestor bar in use, it’s pretty impressive.0 -
I have the win bag that Alan mentions. It might do the trick. I’ve only used mine for accessing vehicles when someone locks their keys in their car.0
2 foot 2x4 on a couple 2x4 blocks. Put blocks near radiator at end 2 sections in from the legs. Kneel on 2x4 lever while you insert the new block.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
Please tell us which if any of these you ended up using, this is becoming an epic thread
@ethicalpaul of course it's epic I chimed in. LOLCost is what you spend , value is what you get.
cell # 413-841-6726
With 2 people I usually have a handtruck on hand and use it as a fulcrum, should be plenty of leverage. The second guy to shim it0
@vilbert_c nope I carry it around in my truck for years. LolCost is what you spend , value is what you get.
cell # 413-841-6726
lever and fulcrum? What was it Archimedes said?
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
