Got a tool tip? You may win a Kinetic Water Ram from General Pipe Cleaners
Erin Holohan Haskell
Member, Moderator, Administrator Posts: 2,318
Once on a job for a given length of time, we all come up with little ways to simplify our work, making it easier to perform. This is especially true in the trades. Maybe you have a way of dislodging wood plugs from a hole saw, a method of fixing a leak in a tight space, or even a technique for descaling manifolds. If you have an idea that has saved you time and money, Plumbing & Mechanical would like to share your tip with their readers. Submit your Tool Tip here. The first-place winner will receive a Kinetic Water Ram from General Pipe Cleaners with a retail value of $325.
President
HeatingHelp.com
OK, I've got one. Here is a photo of a simple tool I made to make working on water heaters a bit easier. This is a solid 3/4" steel rod with a small crossbar welded on top. It slips (or pounds) down into the pipe nipple that doesn't want to come out on top of the heater I'm working on. With this in place, the nipple is not collapsed by the wrench, so it doesn't tear off and leave a steel ring in the threads of the tank. I've heard of using easy out's and such, but this has never failed me.
Yours, Larry
4 -
Great one @Larry Weingarten. To be in the contest, please submit it through that link in Erin’s post above. Thanks.Retired and loving it.0
Hello, Here is another tool for you. This is a simple saw, made from a Sawzall blade, some 3/4" threaded fiberglass rod and a hose clamp. Because of the threads on the rod, it absolutely will not slip in your hand and using a blade stronger than the normal hacksaw blade makes it hold up better to serious usage.
I've submitted both ideas so that we can "bring it home"!
Yours, Larry
I use one of the thousand plastic syringes I have from my daughters medicines (Tylenol, Motrin, etc.) to fill pigtails.0
Hello, Here's another idea. This is reusing a broken pair of pliers. I took the broken tool and ground it down to make a nail set, which is much easier to use than a normal one. Also it puts your hand and fingers well out of the way of the hammer and works in tighter spaces then the traditional approach.
Yours, Larry
Where did the rust come from ? You may need to add a filter in your area, You can sell them a whole house filter ,I am sure the driveway and steps get stain as well if rust coming from the main water. Also flush your hose from the truck . It tends to bring your job to the next ....
Well the golf balls didn't get first place, but did get second. Hopefully one of the other wallies can bring it home!
Good luck!
Dennis0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
